"does anyone sell the body panels for a panel truck"Stovebolt Forums Has a
Panels 'N Burbs forum, just recently there was a person asking the same question..
Here is the thread
Underside rear-cabin corner photos neededHere are some links that are in the above thread.
Jim Carter's listings has the 1947-1955 Suburban, Panel, and Canopy Express Rear Cab Corner .
tclederman has a page on his 1954 Suburban website, it shows some corner
Repair Photos.
1947-1955 1st series Suburban, Panel, and Canopy Express single bodies are virtually the same.
The one ton Panel, and Canopy Express bodies are longer.
As far as your drivetrain, my hunch is they installed 1957 235 with its open drive shaft
TRANNY (bottom trans.). and made a custom drive shaft.
I think they had to use the 1951 bell housing and may had to use a 3 or 4 speed rear tranny mount cross member.
When you swap from a closed to a open driveline you also have to change out the rear leaf springs. (You can flip the leaf spring too)
The open driveline axle housing is solid mounted to the rear leaf springs.
The closed driveline axle housing is mounted to the rear leaf springs using a spring seat with a center bushing.
The spring seat and bushing allows the closed driveline torque tube to swivel when the leaf springs compress.
The closed driveline axle has ears welded on the housing to accept the spring seat which is u-bolted to the leaf springs.
The closed driveline axle rear leaf spring stack center pin is off set to the front.
The open driveline rear leaf springs stack center pin is positioned in the center of the leaf spring.
1947-1954 Rear Spring Alignment .
There wasn't many of the 1955 1st series rear axles made and there is a
1955 1st series Supplement to the 1954 Chevrolet Truck Shop Manual (I cannot find a free one online).
The 1955 1st series Supplement to the 1954 Chevrolet Truck Shop Manual talks primarily about the axle you have. There are 13 pages.
The 1955 1st series Chevrolet Trucks where sold from, September 1954 to March 1955 about 6 months.
