| | | Forums66 Topics128,005 Posts1,055,254 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | Looking to buy a five window cab but the seller can’t find the data plate and has no title. How do you go about finding the vin number and getting a new data plate ? Or is the cab not useable.Can u get a new vin number for the cab ?
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | No number anywhere on cabs of that era. Each State has a process for getting a “New” VIN stamped. BUYER BEWARE!
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If you’re fixing a truck you already have with proper paperwork then the cab without a title sounds like a good donor. Probably not worth the headache and chance to title one with no existing title or numbers. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Pre '56 most states used the engine number as the "VIN" on the title. Like Martin said, contact your state to see what their process is to title your vehicle. Some states are more anal that others.
| | | | | Joined: Nov 2000 Posts: 1,964 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,964 | Whatever you do, don't commit title fraud. And what that is varies from state to state. Apparently there are legal ways to do it because 1000s? of trucks have had the cab changed...
Professional Novice
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | You know I have read these threads over and over in many forums over the years. Chances of the absence of a body tag missing on a truck that originally came with one, is that sometime in the past it was stolen, especially if it has the absence of a title too. So with that said, if you are a law abiding citizen and don't want trouble and don't want to arm wrestle your way out of a potentially nasty situation, you don't go near it.
I personally would not go near anything that should have a number on it that doesn't, although there are states (mine in fact) that say parts that dont have numbers on them should have a bill of sale or documentation on how it was obtained. Even though my state does not have a data base on body tags, it does on engine VINS. Which is silly because the old 216 has been replaced like most babbit pounders have, the reason I kept the block.
So technically, if you buy a replacement engine and it has a ViN number on it that was produced before 1956, it better have a title with it, but a cab with a body number you dont need a title but need a bill of sale or documentation on how it was obtained, but a cab without a body number, even though not tracted in my state you need a title, even though the title cant be tied to that body. Many read between the lines but it cant be said here on the stovebolt. Steve
1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
