Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (homer52), 118 guests, and 6 robots.
Topics128,281
Posts1,058,469
Members48,490
#1290265 12/08/2018 12:41 AM
Getting close to starting the rebuilt 216 engine. It will be the first time in 25 years it will be running Put antifreeze in today and it appears i have a leaks. One was at thermostat. So I made a new gasket , installed it and refilled radiator. Was hoping that was the only one. Tonight the pool of antifreeze under the engine tells me it's not. darn!!!!!!
Check the weep hole at the bottom of the water pump casting. It's not uncommon for a pump that has been dry for years to have a seep leak. SOMETIMES the leak will seal itself up with a little run time. Unless it's gushing, go ahead and fire the engine up- - - -things will get better- - - -ort worse- - - -but unless you run things dry a few seep leaks won't hurt during an initial run-in. Just put a big catch pan under the engine to keep the floor clean.
