| | | Forums66 Topics128,281 Posts1,058,467 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2016 Posts: 182 'Bolter | | 'Bolter Joined: Jun 2016 Posts: 182 | Getting close to starting the rebuilt 216 engine. It will be the first time in 25 years it will be running Put antifreeze in today and it appears i have a leaks. One was at thermostat. So I made a new gasket , installed it and refilled radiator. Was hoping that was the only one. Tonight the pool of antifreeze under the engine tells me it's not. darn!!!!!! | | | | | Joined: Feb 2004 Posts: 29,950 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,950 | Check the weep hole at the bottom of the water pump casting. It's not uncommon for a pump that has been dry for years to have a seep leak. SOMETIMES the leak will seal itself up with a little run time. Unless it's gushing, go ahead and fire the engine up- - - -things will get better- - - -ort worse- - - -but unless you run things dry a few seep leaks won't hurt during an initial run-in. Just put a big catch pan under the engine to keep the floor clean. Jerry
