0 members (), 118 guests, and 3 robots.
Topics128,186
Posts1,057,320
Members48,469
I'm installing a 3" dropped axel on my '59 235 apache. Has anyone had experience in modifying the drag link to keep it level with the pitman arm to avoid the dreaded bump steer. When building the old F*** roadsters they used to heat the steering arm and bend it lower. Can I cut the draglink and rotate the end with the steering arm balljoint to a downward position and then install it on the top of the arm instead of the bottom of the steering arm? I hate to cut the draklink but if I have it Mig welded and pinned inside of a sleeve I guess it should be ok. What do you guys have to say?
hello 4d9r. i made an adjustable drag link by using two new tie rod ends i got at a parts store and threading a tube to accept the male theaded ends. i brought the old drag link to the store to match up the tapered part of the joints.
our garage is a non-profit organization
