| | | Forums66 Topics128,196 Posts1,057,393 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2000 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2000 Posts: 81 | I currently have a 63 chevy short bed stepside. The question I have is do I lower it, or 4x4 it? The truck has many problems that money and time will fix. Since I have a 77 K-5 4x4 frame, and a 89 Caprice, I can go either way.  I have checked the dimensions and the 89 Caprice frame will work. I will have heavy duty discs up front and a rear sway bar. Plus the motor and transmission.
If at first you don't succeed, get a bigger hammer.
1941 Pontiac business coupe 1947 Chev Coupe 1969 GTO ragtop
| | | | | Joined: Jun 2002 Posts: 7 Member | | Member Joined: Jun 2002 Posts: 7 | Low...slow... with alot of go is my vote.Airbag the suspension and throw some '20's on it!I've swapped bodies before from 2wheel frame to 4wheel using a 3ton engine hoist and blocks to seperate/transplant to a 4wheel frame.I did it in one weekend with hand tools-solo.But that was with a '73 fulltop blazer.I've also converted my brothers 4 wheel '72 blazer from 4 to 2 wheel by swapping front crossmembers,rearends and drive-trains.Take good measurements prior to ripping everything apart,take pictures with a disposeable camera for reference purposes,and go at it.Anythings possible with a sawsall,a torch and a little time- enjoy yourself. | | | | | Joined: Apr 2000 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2000 Posts: 81 | Thanks for the info! I'll stick with my original pan to go lo,' as you say.
