| | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2013 Posts: 148 Shop Shark | | Shop Shark Joined: Jun 2013 Posts: 148 | I have a 54 3600 with the CCP front disc brakes and power booster. Its been fine for three years and just last week I smelled brakes on a 10 mile drive. The front wheels were hot but the backs were fine. I jacked up the truck and couldn't spin the front tires until I cracked the bleeder screw. I pumped the pedal 2 or 3 times and the wheels locked up again. I pulled the calipers off and the pistons pushed in with a c clamp without much resistance. Could it be in the master cylinder or the residual valves? I don't want to start replacing parts I don't need to. Need help on diagnosing please. Thanks Sharon | | | | | Joined: Feb 2004 Posts: 29,774 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,774 | Why do you have residual valves on disc brakes? Jerry
| | | | | Joined: Jun 2013 Posts: 148 Shop Shark | | Shop Shark Joined: Jun 2013 Posts: 148 | I thought they might be built into the master cylinder. UPDATE. I adjusted the rear shoes and found they do not bind at all only the fronts. There is 1/8" free play in the pushrod to the booster also. | | | | | Joined: Feb 2004 Posts: 29,774 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,774 | Try loosening the flare nuts upstream of the flex lines in the front. It's unusual for both flex lines to fail at once, but not impossible. If the calipers stay applied with the metal lines vented upstream of the flex lines the flex lines have collapsed inside.
Edit: some boosters have an adjusting screw between the booster diaphragm and the master cylinder, but that one would probably affect all the brakes if it's out of adjustment. Jerry
| | | | | Joined: Jun 2013 Posts: 148 Shop Shark | | Shop Shark Joined: Jun 2013 Posts: 148 | Thanks Jerry, I will give that a try. Sharon | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Sharon, This explains why your front disc brakes have residual pressure valves: https://techtalk.mpbrakes.com/how-to-series/four-things-to-know-about-brake-valvesObviously your overall system is correct for your application or it wouldn't have worked perfectly for 3 years. Now something is keeping hydraulic pressure on your calipers when you take your foot off the brake pedal. I would use a process of elimination releasing pressure at the MC flare nut first, then at the residual pressure valve and finally at the caliper and see where in the system the blockage is. Good Luck!
Ray
| | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | You need residual valves because the master cylinder is level with the calipers without the residual valves the brake fluid will back flow into the master cylinder . There’s one for the front and for the rear
| | | | | Joined: Feb 2004 Posts: 29,774 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,774 | If residual valves are used with disc brakes, they need to be VERY low pressure items. Calipers have no springs to retract the pads away from the rotors, so residual pressure in the lines above a pound or two will create drag and overheating. It also takes very little pressure to move the large diameter caliper pistons, compared to a drum brake wheel cylinder. The heavy spring pressure of drum brake shoe retracting springs allows much higher static pressure to remain in the lines, which also keeps the wheel cylinder cups expanded against the cylinder walls to avoid air leaks into the fluid. Jerry
| | | | | Joined: Jun 2013 Posts: 148 Shop Shark | | Shop Shark Joined: Jun 2013 Posts: 148 | Thanks for the info. I will remove the flex hoses first and see if I blow thru them. then onto the calipers being the right side drags considerably more than the left. Sharon
| | | | | Joined: Jun 2013 Posts: 148 Shop Shark | | Shop Shark Joined: Jun 2013 Posts: 148 | Pulled of the right flex hose tonite and you can blow thru it. Ordered a couple of caliper kits and will put them in in a couple of days. Keep everyone informed. Sharon | | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | Sharon............did you get the brakes fixed ? What was the cause ? | | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | Sharon............did you get the brakes fixed ? What was the cause ? Still curious ...........fixed ??? | | |
