2 members (Jims46, klhansen),
125
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,151 Posts1,056,995 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 18 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 18 | hi,
i am looking for gaskets for rear axle (front/rear diff, and axle) for my 1954 1 ton / 3800, Eaton H052/72. i cant find any dealers who sells these. anybody know where to get them?
take care.
-morten- | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Yes, The part numbers are listed in this tech tip, available at any auto parts store over here. https://www.stovebolt.com/techtips/axles/1%20Ton%20Upgrade/Differential carrier gasket: Felpro RDS5090 (the thin one) Rear diff cover gasket: Felpro RDS5088 (the thick one) Axle flange gasket (x2): Felpro 55350 | | | | | Joined: Aug 2018 Posts: 18 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 18 | | | | | | Joined: Feb 2007 Posts: 15 New Guy | | New Guy Joined: Feb 2007 Posts: 15 | The drop center Eaton H052/72 was used by GM (Chevy more than GMC) until 1972 in the C and K ,20 and 30 series, in the 10/15 half tons there where used until 1966. Hope this helps broaden the search pattern.
~Boone 1932 Confederate 5 window Sport Coupe 1936 Chevy 1/2 ton pickup 1953 Indian Chief 1947 Indian Chief 1946 Indian Chief
Collector of Vintage Indian motorcycles pre '1953
| | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | I found mine at my local NAPA. Took a day to get them in. Third member and axle gaskets for an HO72 on a 1949 3800 with 4.10 ratio rear end from a 68-72 chevy. Find the grey haired parts guy who can still use a paper book... | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | But wait, you are in Norway.... pm me. | | | | | Joined: Aug 2018 Posts: 18 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 18 | Found the parts i needed.
thanks for all help. | | |
