Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
8 members (Thom75, dt235sd, BC59, Guitplayer, cmayna, 66flea, Bill Hanlon, 1 invisible), 191 guests, and 4 robots.
Topics128,282
Posts1,058,497
Members48,490
#1289141 11/29/2018 12:26 AM
I'm looking for bench seat suggestions for my '48. The original seat riser or base was previously cut out. Does anyone know of any other make/model seats which fit well in the AD trucks?
Fox Offline
I removed my riser in my AD as well. I welded in 1” square tubing along the floorboard as a spacer, drilled some holes, and installed 88-93 Chevy/gmc bench seats. They are wider than stock and nearly touch the doors on both sides, but they give tons of head room, leg room, are easily adjustable and sit at the perfect “hang your elbow out the window as you cruise” height.
I got my seat for $50. Deep steam cleaned for $50. Very happy with it.
https://photos.app.goo.gl/V6XZKZdwbqBKscCZ6
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Thanks Fox! That definitely looks sweet! I'll start hittin up the pick and pulls!
I found one locally today on CL and got it for $35. Thanks again Fox!
Fox Offline
Happy cruising. 👍🏻
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Moderated by  ndkid275, Phak1
