| | | Forums66 Topics128,076 Posts1,055,922 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 40 Member | | Member Joined: Feb 2001 Posts: 40 | I want to convert my stock mustange-2 lower strut rod into the type like you see being sold in the magazines for around $120.00 - with a pivot/bushing. I want to weld a 4-bar end onto the strut rod where it will line up with the control arm pivot thus making it an A-arm . My question is who sells these weld on ends ? It is a metal tube section with a bushing ( rubber or poly ) and is made to weld onto one end of a 4-bar set up . ( not the threaded on end ) | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | Pete and Jake hot rod parts. They have had them for 20+ years in their catalog.
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
| | | | | Joined: Feb 2001 Posts: 40 Member | | Member Joined: Feb 2001 Posts: 40 | Thanks alot ! I'll check with them . | | |
