Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Otto Skorzeny, 55shaker, Ribside), 128 guests, and 5 robots.
Topics128,281
Posts1,058,478
Members48,490
#128907 01/20/2002 5:56 AM
I want to convert my stock mustange-2 lower strut rod into the type like you see being sold in the magazines for around $120.00 - with a pivot/bushing. I want to weld a 4-bar end onto the strut rod where it will line up with the control arm pivot thus making it an A-arm . My question is who sells these weld on ends ? It is a metal tube section with a bushing ( rubber or poly ) and is made to weld onto one end of a 4-bar set up . ( not the threaded on end )
#128908 01/20/2002 10:23 PM
Pete and Jake hot rod parts. They have had them for 20+ years in their catalog.
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
#128909 01/21/2002 4:31 AM
Thanks alot ! I'll check with them .
