4 members (Hotrod Lincoln, FishinToms53, Bill Hanlon, Charles in CA), 71 guests, and 3 robots.
Topics128,087
Posts1,056,000
Members48,430
#1288995 11/27/2018 6:50 PM
my serial number on the motor in my 48 chevy 2 ton truck is F0921A can anyone tell me the year made ?
I just finished a 1946 chevy pickup street rod
now on a 1950 chevy 3100
also a GMC 220 with duals
and a 1948 chevy 2 ton
Not from that code.
Post the various codes from the locations shown on the link below:
http://www.1954advance-design.com/Web%20images/casting-code-photos/codes-ser-nums.html
That will allow people to help you ID your block and head.
It is most likely 1957 or later.
thanks! got it!
As Tim said, you can't ID the year from this engine code as the suffix "A" was used from 1957 thru 1964.
F0921A
F = Flint Engine Plant
09 = Month
21 = Day
A = 235 (1957 thru 1962) or 230 (1963 or 1964).
You'll need to find the date code to determine the year and the casting number to determine if it's a 230 or 235.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Just look at it, you dont need numbers to see if it is a 230 or 235
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
" . . . can anyone tell me the year made ?"
230 engines started in 1963 and replaced the previous generation stovebolts, the only thing similar is they have 6 cylinders inline.
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
I know the 235 and 230 are physically different, LOL (poor choice of words by me). I should have said the only way to date an "A" suffix 6-cylinder engine built between 1957 and 1964 is by looking at the cast date code.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
my block casting number is 3769716. Different sources tell me different info
I figured you did Mike, the only reason I posted was to clarify encase somebody finds this thread later on a search and gets confused.
Steve
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
