2 members (greenie-reddy, carbking), 47 guests, and 7 robots.
Topics128,021
Posts1,055,355
Members48,420
#128898 12/18/2002 5:09 AM
Just wondering what anyone might recommend for an shifter(floor) for the 4L60 that's in my '46 pickup. There's a million different choices out there. Anyone had any good/really bad experiences?
Rollin' Hard
1946 Chevy 1/2 ton
1959 Phord 1/2 ton
2001 Chevy 1/2 ton
#128899 12/18/2002 7:32 AM
I really like my Lokar shifter for the turbo 350. It was easy to install and adjust. I even mounted the factory park brake lever to it. Joe
#128900 12/18/2002 9:24 AM
STAY AWAY FROM TCI.. MINE SUCKS.. but i'm stuck with it until it breaks.. Locar is the way to go.
Another quality post.
Real Trucks Rattle
#128901 12/18/2002 2:52 PM
Lokar is the best in the biz. You can get them any way you want, just about.
JAKE
1949 Chevy Styleline Coupe
CARBOLT
#128902 12/18/2002 6:16 PM
Lokar it is I guess. Thanks guys.
Rollin' Hard
1946 Chevy 1/2 ton
1959 Phord 1/2 ton
2001 Chevy 1/2 ton
#128903 12/19/2002 9:27 PM
I have used both the Lokar and the Gennie Shifter on a 350 TH and 400 TH respectively with success. Gennie Shifter Lokar
There is no problem so great that it cannot be solved by the application of thought, elbow grease and copious amounts of CASH.
Snappy
#128904 12/26/2002 7:07 AM
Snappy-
I'm interested in thee same basic question. Any big differences between Gennie and Lokar? Plusses and/or minuses? Does Lokar offer a shift indicator?
51 PhatBoy
#128905 12/26/2002 1:13 PM
smile howziit guys!
i guess you guys don't mind having a stick between your middle passenger's legs.
me...i like my floor bare,with as much space as possible, for my passengers.
right now, i have a shifter on my tilt steering column.
HOWEVER...i have a new Hurst pro-matic ratchet shifter, which i intend to install on the ledge between the driver's door panel and the driver's seat.
JMO, the LOKAR shifter is not a performance slamming-jamming floor shifter. since it's not, i have no intention of sticking a shifter like that, between the passenger's legs.
i might as well leave it on the steering column! :rolleyes:
Myron
1956 chevy 3100 stepside, Pro-Street stance, mild 454 BBC/350/9"/13" M/T'S, daily driver, aka THE PINK LADY
1957 Bel-Air coupe, 500 HP blown sbc in progress, aka LANI
#128906 12/26/2002 7:31 PM
Anonymous
Unregistered
Anonymous
Unregistered
My cab is too small for a middle passenger.. unless they weigh less than a 100 lbs each..
