| | | Forums66 Topics128,105 Posts1,056,545 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | ** Can anyone enlighten me as to the best fix for very loose shift lever retainer pins? ** One on each side of the tower that the shift lever goes into. Both pins on my 1953 SM-420 transmission are very loose with both holes the pins go through enlarged due to the pins bouncing around for many years. Thanks | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I have made oversize pins by cutting the shank off an appropriate size drill bit. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | ** That's a thought but how do you retain them to make sure they don't loosen up and fall down into the transmission? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | You need new fulcrum pins - GM # 590282 About now people step in and discuss ways to modify and replace with something not original, and generally drill out the holes (bugger things up) so you could never use the original parts again, I've even done that before I knew better. The following thread starts out that way but ends with some great info on original parts https://www.stovebolt.com/ubbthread...d-up-4-speed-gear-shift.html#Post1194887 | | | | | Joined: Oct 2012 Posts: 130 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 130 | I put new fulcrum pins in my 49-3100. On the new pins I put a fine thread on half the end that goes thru the housing. Used a Nylon lock nut to hold in place. Has been working for two years with no problem. With new pins shifter is tight. | | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | ** Thanks for the great reply's. ** For those with the same problem with their SM-420 and are not locked in to being completely original the fix mentioned by "Fox" seems like a great idea. Thanks Again to all for the great information. | | |
