1 members (Hotrod Lincoln),
41
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2017 Posts: 55 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 55 | Hi fellow Stovebolters, I’ve got a 1942 (model MS) 1.5 ton flatbed. I’m trying to figure out what year engine I have in it. Every link that I’ve looked on it does not show the letters/numbers of what I have. Maybe one of you seasoned Stovebolters can assist. Just to the left of the distributor on that ledge where the engine numbers are reads F0214BE. Thats it. nothing more nothing less. From what I can tell, and its an uneducated guess at best....its a 1948 235 Load Master. Any help will greatly be appreciated | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | You have a 1960 or 1961 235... F0214BE F = Flint Engine Plant 02 = Month (Feb) 14 = Day BE = Passenger Car with Power Steering and a Powerglide. "BE" was used in 1960 and 1961. Mike B  | | | | | Joined: Nov 2018 Posts: 4 New Guy | | New Guy Joined: Nov 2018 Posts: 4 | | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Tim, The OP was asking about suffix code "BE" which is a 235 6-cylinder (60-61)...you're asking about suffix code "E" which is a 283 V8 (57-61 as you stated). Mike B
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks, Mike - sorry
You did state/show the BE suffix. | | | | | Joined: Aug 2017 Posts: 55 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 55 | Perfect. thanks Mike B and Tim. | | | | | Joined: Jul 2012 Posts: 10 New Guy | | New Guy Joined: Jul 2012 Posts: 10 | I don't mean to jump on someone else's thread. I have a 235 with the S/N F904B. What I can figure out is F= Flint 904= Sept 4th But I can't find out what the B is for. Any help would be greatly appreciated | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | The engine suffix code "B" was used from 1957 thru 1964 to ID the Passenger Car 6-cylinder with Powerglide... The engine casting date code will ID what year it was made. Mike B  | | | | | Joined: Jul 2012 Posts: 10 New Guy | | New Guy Joined: Jul 2012 Posts: 10 | | | |
