1 members (klhansen), 70 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
#128892 04/11/2003 12:57 AM
What is my best bet for installing brake lines for 4 wheel discs, camaro front and rear?? Also- Do I need 2 boosters- or is it just as easy to bleed em with the single and get the correct braking amount on the front and rear?
Your best bet would be to use the 4 wheel disc brake master cylinder, booster and combination valve off the Camaro.
Joe
I agree with Joe, as a matched set is best and perhaps easy to salvage. Are you using Camaro firewall pedals or grafting the booster to a trucks original floor pedals?
If you're buying new components, there are many options using a single booster and proportioning valve. I understand that the design of these are very similar to late model GM. Assuming this is going in your truck, there are options for firewall or under cab mounting these components.
