7 members (Jay R, Oswald, 55shaker, Joe H, Jon G, Phak1, dt235sd),
86
Mod | | | Forums66 Topics128,268 Posts1,058,391 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#12884 01/31/2005 8:04 PM | Joined: Jul 2000 Posts: 53 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 53 | Has anyone tried drilling out the jets on multiple Rochester setups as suggested in the www.inliners.org tech tips? If so, what was your experience? 11. Start with your smallest number drill and try pushing it through the restriction located under the alum. plug. Go up one drill size at a time until you find the largest that will go into the restriction. See Fig. F. In my carbs that was a .070" drill. Now take the very next drill size larger, place it in a pin vise (cheap), and drill out the restriction. See Fig. G. Go far enough so that you see the end of the drill in the center vent hole. Put everything back together and drive it again. You may or may not see an improvement. If not, or if its not enough, go through it all again with the next size bigger drill bit. Keep going until the hesitation is fixed. I ended up using a .078" which worked quite well on my duals and on another triple set up. Both were 261 engines. Remember this effects only the off idle under gentile acceleration. It also enriches the idle mixture so that a needle adjustment will be necessary. How did all this sawdust get under the hood? | | |
#12885 02/01/2005 5:16 PM | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | tree91 - I'm going to bump this up to the top for you, because I would also like to know if anyone had had any experence with tihis process. I have also seen posts that talk about cutting the length of the spring on the power valve. Has anyone done this? Does it work? Come on guys lets hear from you :confused: George | | |
#12886 02/01/2005 5:42 PM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | I used 2 monoleaks on my on my Packard and used the inliner tech tips as a guide......worked well !! | | |
#12887 02/01/2005 6:59 PM | Joined: Aug 2001 Posts: 154 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 154 | Never worked for my Roch-B's or box of B's couldn't get 'em sync'd tried to match up parts as it seems there are many variation of B's. My six departed this life, I now have a 350 Vortec with EFI swe-e-e-et. Zeke
The Amish Connection 51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
#12888 02/03/2005 10:00 PM | Joined: Jul 2000 Posts: 53 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 53 | Mr. Proffit, what size drill did you use to drill out the jet, and how did you replug the access hole? How did all this sawdust get under the hood? | | |
#12889 02/03/2005 10:57 PM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | DRILL SIZE????? Don't they give you a starting place? It was a long time ago and on my Packard First thing was to make sure both carbs were the same in every way
I used some led shot from the fishin' store to cover the hole
It was all pretty easy | | |
