3 members (RoadsScholar, Gdads51, Gray_Ghost), 120 guests, and 4 robots.
Topics128,078
Posts1,056,021
Members48,433
#1288283 11/21/2018 2:51 PM
We r rebuilding the driveshaft in our 55.2 3600 chevvrolet 3/4 ton truck.
Its a longbed and the driveshaft has a carrier bearing in the middle..
Needs replacement but cant find a # on it or a replacement from lmc or brothers truck.
Anyone know what might work as a replacwmwnt part #?
1952 GMC model 473 dump truck
1951 Chevy 1500 stepside
Rockauto.com has at least a half dozen to choose from. Search 1956 Chevy truck.
Also search here for discussions about 1 ton through 2 ton, same carrier bearing.
I recall original part numbers, new part numbers to rebuild the original, and part numbers for modern replacement all being discussed.
https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/showflat/Number/1254876/Searchpage/1/Main/183295/Words/%2BCarrier+%2Bbearing+%2B/Search/true/1-ton-carrier-bearing.html#Post1254876
•1952 Chevrolet 3800 pickup
---All pictures---
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
