1 members (RLB),
215
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 193 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 193 | We r rebuilding the driveshaft in our 55.2 3600 chevvrolet 3/4 ton truck.
Its a longbed and the driveshaft has a carrier bearing in the middle.. Needs replacement but cant find a # on it or a replacement from lmc or brothers truck.
Anyone know what might work as a replacwmwnt part #?
1952 GMC model 473 dump truck 1951 Chevy 1500 stepside
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Rockauto.com has at least a half dozen to choose from. Search 1956 Chevy truck.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Also search here for discussions about 1 ton through 2 ton, same carrier bearing. I recall original part numbers, new part numbers to rebuild the original, and part numbers for modern replacement all being discussed. https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/showflat/Number/1254876/Searchpage/1/Main/183295/Words/%2BCarrier+%2Bbearing+%2B/Search/true/1-ton-carrier-bearing.html#Post1254876
| | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 |
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
