2 members (ChevyBlue, Otto Skorzeny), 224 guests, and 8 robots.
Topics128,077
Posts1,056,033
Members48,433
#1288327 11/21/2018 8:56 PM
Do tri-5 have the same mounting method as AD trucks?
I boogered up my steering shaft threads. Anyhow, since I’m going the power steering route, I’m looking at my options.
I can find Tri-Five steering shafts, so I’m just thinking it may be an option.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Riding in the Passing Lane
The mounting for the steering wheel is the same. There are variations in length. The 57 up is shorter then the 55-56. as they have the dish out steering wheel.
George
1972 Chevy c10 Cheyenne Super
All I’m really after is the shaft. I’ll use it in my truck along with a column saver bushing. Thanks.
"The Fake Truck"
Sir Searchalot
Sir Searchalot
Depends on what you mean by "mounting method". I assume you mean the steering wheel? (your title says wheel but you ask about shaft) Or do you mean the shaft? The steering wheel splines are the same from way early to way late Chevys.
I guess I should’ve asked, “Is the splined end and nut the same?” That’s all I really wanted to know. For my purpose it doesn’t really matter if it’s a car, truck, whatever. I need a 3/4 shaft with a splined end and a 1/2” nut, that’s it.
Sorry for being vague, I found out what I needed to know anyhow.
"The Fake Truck"
Sir Searchalot
Sir Searchalot
Understood. Edited/shortened my post.
Big Bolt Forum Moderator
too bad you are not closer, I have a shaft that someone cut off where it goes into the box leaning up against the wall in the shop! LOL. You should be able to find one close to you I would imagine, should be a lot of them that will work for you!
Mike
Mike
Thanks for the offer, if you were about 1800 miles closer it would work, I suppose. LOL.
I’m trying to figure out my options. I can find find the Tri-Five stuff all over the place, new and used parts. For whatever reason, I’m having trouble finding the truck stuff.
The crowd I run with are more into motorcycles and lifted trucks. I’m the only one that likes old trucks. Maybe I need new friends I guess.
"The Fake Truck"
