2 members (78buckshot, 1 invisible), 390 guests, and 5 robots.
Topics128,162
Posts1,057,042
Members48,463
#1288279 11/21/2018 1:58 PM
Thank You for info and apologize for posting on wrong thread , the small power supply for boosting to 12V sounds like a simple fix , is there a name for a power supply that you would suggest and where might I buy such a unit ?
https://www.classiccarstereos.com/6v-12v-converters.html (6v neg to 6v neg)
https://www.classiccarstereos.com/positive-ground-6v-to-12v-converter.html (6v pos to 12v neg)
Those are sold by many venders - check around for price.
Maybe someone has used on of these?
Says it will work with positive ground.
I didn't know they made one that runs on a positive ground but that is nice. The one similar to mine is listed on Ebay as a MWX Converter, item #113349267583. I found that with a search criteria "MWX converter 5V to 12 V".
1951 1 Ton Completed
Thank You for the info , will look into it .
Is that Amazon unit OK with a positive ground 6v system?
Moderated by  truckernix
