1 members (klhansen), 70 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
#1287836 11/17/2018 3:33 PM
I have a 63 c10 230 w/ granny 4 speed. I believe it’s a 1/2 ton
I’m looking up clutch parts and some places say 10 inch others say with 4 speed it’s an 11 inch
How do I tell before removing trans
Schetk
schetk #1287857 11/17/2018 6:12 PM
Sir Searchalot
Sir Searchalot
Probably 11 inch but you don't need to know before removing trans. Standard came with 10". A 230 could be ordered with 11" and a 4 speed came with 11".
You never know what the many previous owners did.
Curious why you don't know if it's a half ton? Vin tells you. Also, 6 lug wheels= 1/2T, 8 lug= 3/4 and up. No shortbed 3/4T.
bartamos #1288036 11/19/2018 4:26 AM
ok thanks, i was just wanting to order the disc and PP before removing, when i go to autozone or oreilly they don't specify 3 speed or 4 speed and only offer the 10 ice, but i can't remember were i saw that 4 speeds had the 11 inch even with the 230.
Schetk
schetk #1288048 11/19/2018 7:55 AM
Sir Searchalot
Sir Searchalot
O'Reilly's, Summit, Jegs, Rockauto and many others sell 11" clutch for a 1963 230. They can't tell you what you actually have anymore than I can. Generally they are not listed by transmission. You have to take it apart or otherwise measure. As I said, it can have a 10" or an 11" or maybe a 10.4". Should have an 11" because the 4 speed came with an 11", as I said. Things like that can get changed around by PO's. If you don't need to drive it for a while, just tear it down and then order. Prices are all over the place. From $80 per set to hundreds.
I would think you can put in an 11" regardless of what is has, but can't be sure. Possible your flywheel/bell housing might restrict you.
bartamos #1288097 11/19/2018 9:21 PM
Ok thanks, but another question, I have the 3rd 4th synchro going out, I was going to replace, but they are getting scarce, has anyone bought kits from transmission direct out of New Jersey?
I would like to have gone with novack but they no longer carry?
Schetk
schetk #1288098 11/19/2018 9:40 PM
Schetk, just a word of advise. When changing topics it is best to start a new thread. Why? It helps others using our search engine, in this case searching for clutch size. They may not be interested in syncros. Thanks, The Stovebolt Staff
schetk #1288111 11/19/2018 11:28 PM
Sir Searchalot
Sir Searchalot
The SM420 can still be bought used in some areas for less than a rebuild/parts. They are somewhat bullet proof and a bad one is rare. They can be inspected a little before buying. $50-$350 in the donor market.
schetk #1288118 11/20/2018 12:12 AM
** Just purchased a SM 420 for $100 was caked with 65 years of crud so could not tell a whole lot on condition on the outside. Spent it's whole life in a 53 3100, removed the side plate & looked really good inside with the exception of the granny gear had the leading edges of the teeth worn a little. Figured most of the SM 420's would probably show the same thing after 65 years as the 1st gear is not synchronized. **
schetk #1288140 11/20/2018 2:28 AM
Sir Searchalot
Sir Searchalot
Gears have a lead-in chamfer on their edges.
