5 members (Forty9, dt235sd, FAST55, Otto Skorzeny, 1 invisible), 81 guests, and 1 robot.
Topics128,050
Posts1,055,754
#1287946 11/18/2018 5:35 AM
Anyone know what goes in the two holes that are next to the toeboard on each side of the cab. The part seems to be spot welded at the top. I'm assuming the are guide holes durring assembly. See pic.
Second question is what are the right bolts for the front of the seat riser, that go through the frame with a spring on the bottom. I have a square nut head on the passenger side and a normal bolt on the driver's side.
Gray46 #1319856 07/30/2019 8:49 PM
I was wondering the same thing - puzzling!
1946 1/2 ton
Moderated by  ndkid275, Phak1
