0 members (), 85 guests, and 0 robots.
Topics128,115
Posts1,056,291
Members48,439
I am trying to wire up my heater and heater switch. I have one wire coming out of the heater (for the fan motor) and two terminals on the switch. I assume the fan motor wire goes to the switch. Where do I get power from? Thanks for any help.
Crusing in the Passing Lane
The system might allow for a two speed fan, does your switch have 2 positions plus off? Easy to check continuinity with an ohm meter or battery and light bulb. Might be that one Wire goes to one contact on switch, other gets hot by switch movement?
Ed
Riding in the Passing Lane
You get power from the accessory side of the ign. switch. Hook an inline fuse to it & run the wire to the switch. The other term. on the switch goes to the heater motor. You can get a switch at the parts stores with resisters built in so you can vary the speed.
George
1972 Chevy c10 Cheyenne Super
Get a VOM(bolt-ohm-Meter) so you can figure this out on your own, they even have ones with a noise when one has continuity for those who are blind.
Ed
