6 members (Charles in CA, lumbersawyer, Rustnut, Hotrod Lincoln, Donf, 1 invisible), 64 guests, and 4 robots.
Topics128,203
Posts1,057,414
Members48,471
DLBrooks
DLBrooks
Did the 41-46 Big bolts only have 6 blade fans, or if any truck was ordered with a shroud have 6 blade fans? With or without heavy duty radiator. I kninda unknowingly put a 4 blade fan with shroud on the 3/4 ton. If I had remembered I had it, I would have used the 6 blade. I have no overheating problems on the 3/4 ton --- 235, 4 blade fan with shroud ---light duty radiator all off a 1.5 ton.
Just curious.
1959 GMC 100 Fleet
Follow in the DITY
Based on WW2 Canadian Army Chevrolets, the same weight class truck could be fitted with either 4 blade or more fans depending more on where it was expected to be used (Africa, India, UK, arctic?) than the weight class (3/4 ton to 3 ton load). The radiators also didn't change much, if at all for the different weight classes. All very nice - if it looked the same and fit the same it would basically work the same...
DLBrooks
DLBrooks
Correction on my initial post. The 1.5 ton had the heavy duty --thicker radiator.
1959 GMC 100 Fleet
Follow in the DITY
Crusing in the Passing Lane
I once saw a 1.5 or 2 ton Chevy fuel tanker with what appeared to be a factory radiator that was very thick.
Ed
