Topics128,132
Posts1,056,391
Members48,441
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
While doing a farm cleanup I found a Evans Mfg. 6 volt heater in a grainery. Data plate shows Evans Mfg Co. Detroit Michigan, 6 volt, model #206475. It looks to be in good condition. Can anyone tell me if it's used on Chevy/GMC's? So far I only have one picture of it sitting on a couple of buckets, more later. Thanks in advance JP
It's not genuine GM, it's after market and could have been installed in almost anything...
Mike B
Crusing in the Passing Lane
If one is thinking of using it, core should be replaced with modern if 12 lb. or so pressure cap is used. Most motors are easily replaced. Ed
I don't plan on using it. Thought someone else might need it. But if it's just a universal heater, it's not worth the trouble. Thanks JP
