3 members (Rusty Heaps, Otto Skorzeny, mo2cyl), 158 guests, and 2 robots.
Topics128,034
Posts1,055,536
Members48,425
#1287209 11/12/2018 9:52 PM
Dumb question guys...I’m replacing my brake and fuel lines with new copper/nickel tubing. I was guessing and ordered 1/4” tubing. Once I got the lines in and a caliper out, I measured the brake lines at 1/4” and the fuel line at 5/16”. I have bent the brake lines but stopped before I got to the thicker diameter fuel line. I have enough 1/4” line left over to plumb the fuel line with 1/4”. Would it be detrimental to use the 1/4” tubing for fuel line on a stock setup (216 w/ stock carb) or do i need to order a spool of 5/16” tubing to use for the fuel lines? Thanks!
Why order a whole spool? Go to your FLAPS and buy a 4 foot section of 5/16" line with two inverted flare nuts already installed. Bend to fit, and cut and re-flare the tubing for one fitting.
Use 5/16” as it was originally.
1952 Chevrolet 3800 pickup
---All pictures---
Skip the 1/4 for the fuel line. If 1/4 was sufficient, the factory would have used it. Better to use the 5/16 then find your self conking out somewhere because the 1/4 is insufficient.
Mike
Yup to the above
Craig
We don't have a flaps. 5/16" only available in steel on the shelf locally. The copper/nickel sure does work easy. I'll source some 5/16". Even if I end up with an entire spool.
Temple Texas doesn't have an Auto Parts Store? I thought everything was bigger in Texas! At least that's what you tell us Okies. eeeek
How would that happen?
If this was a 500 inch motor that needed plenty of fuel, then yes, go with bigger line. 1/4 should be plenty for a 216. You have the line, might as well give it a go.
aggie,
Apparently you have a couple advance auto parts stores in Temple. Their website is selling 5/6" copper/nickel tubing in 5 foot sections. Call them up. Or order online and pick up locally. Or move near me and I'll give you some nanner
Craig
Google shows all the usual suspects, O’Reillys, Autozone, Advance and NAPA in Temple. Could it be that aggie jon doesn’t know what Friendly Local Auto Parts Store is? Maybe he’s pulling our leg. 🤪
!/4" line is plenty big enough for a 216. Fords of that era were 239ci V8 and used a 1/4" line all the way from the tank to the carb plus they turned way more rpm's than the Chevy.
Evan
I know where the auto parts stores are cmayna. I personally visited the advance store. I asked, They said they would have to order it. Every store has everything online. No store has it in store on the shelf. They can all get it ordered in. I can do that myself on amazon. And I don't have to make a second trip into town to run it down. I have my preferred parts guy on speed dial at NAPA.
Dead issue. line has been done.
