8 members (Rusty Rod, TUTS 59, Peggy M, 3B, J Lucas, David Bush, Southerntruck, 1 invisible),
103
Mod | | | Forums66 Topics128,065 Posts1,055,863 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 2,404 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,404 | To the best of my knowledge, 1957 to 59 half ton Chevy frame, axles, linkage, shock mounts, steering box etc are the same. Both have short boxes although the 57 is a stepside and the 59 is fleetside. Everything mechanical underneath should interchange. Does that sound correct?
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Yes and no...the mechanical stuff is the same, but the frames are different between the 55-57 and 58/59. The 58/59 frames are longer at the front bumper. Mike B  | | | | | Joined: Nov 2004 Posts: 2,404 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,404 |
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Dec 2011 Posts: 112 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 112 | J Lucas You will likely find that brake line from master cyl to rear axle assembly differ from 57 to 59. On 57 it crosses over to right side frame & back to rear axle. On 59 it goes back on left side to rear axle. FYI delky dave in wyo
1957, 3100, v8 2016 gmc 4wd
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | 58 and 59's also had a stepside in addition to a fleetside. Rear backing plates are slightly different and use the wider rear brake shoes to match the fronts. Fred
