7 members (Gdads51, Hanks custodian, Steelonsteel, TUTS 59, Mike Burns, Wayne67vert, 1 invisible), 86 guests, and 3 robots.
Topics128,066
Posts1,055,871
Members48,428
#1287224 11/13/2018 12:23 AM
Trying to get the ignition out of my dash. Assuming that it has a screw on bezel. It has two small holes on each side of the ignition, see pic. Any advice on easiest for way to remove.
I'm able to remove the key cilender without issues.
Justin
Y
yar Offline
Y Offline
Justin,
That comes off easily with a pin spanner wrench. here's an example:
https://www.sears.com/williams-ws-4...p;prdNo=3&blockNo=3&blockType=G3
If you have a hole saw the size of the bezel a pin spanner would be easy to make. You could also use Channel lock pliers and protect the bezel with a piece of leather.
Ray
Greatly appreciate the quick response. Take care
Moderated by  ndkid275, Phak1
