5 members (Otto Skorzeny, Erniegp, Hanks custodian, 2 invisible), 49 guests, and 2 robots.
Topics128,054
Posts1,055,780
#1286605 11/08/2018 5:41 PM
Is it possible to torque all, or like we call it Flight line torque the Bell housing bolts without removing the clutch/ flywheel assembly?
Crusing in the Passing Lane
What engine?
Ed
235' 6 cylinder.
Nope, I presume the bellhousing to block bolts.
Ed
Looks like there are 2 bolts way up inside the bell housing I can not get too.
With the flywheel removed, all can be removed or tightened with a .5" drive socket set with U- joints.
Ed
It's not possible to get accurate torques when using a u-joint. If there's any angle at all on the u-joint, the torque reading will not reflect the actual torque.
A better approach would be to use a crowsfoot installed at a right angle to the torque wrench if it's not possible to get the torque wrench on the bolt with a socket on it.
With a little mathematics you could use an extender in line with the wrench stem.
Why bother torquing? Like my first shop foreman used to say about cylinder head bolts- - - - -"Give 'em a good grunt!" (No, I didn't do it that way), but he would always give me the stink eye when I got out the torque wrench!
Torque 'em down till they break and back off 1/2 turn. eeeek
Boy am I feeling lucky. I've never torqued a bell housing onto an engine in 55 years of backyard/barn monkey wrenching and have had no problems. I have replaced bell housings for others that had ears broken off and/or cracked. Too much torque or not enough?
Rick
1939 Chevrolet Stake Truck
Rick
Yes.........we are NOT working on the bell housing on the space shuttle.
Cracked causes .........misaligned, missing dowel pins or tightened when not seated against the block?
Proper/Correct Torque = 1/4 turn before you wring it off
Mike
1951 3100 5 window
The most common cause of a broken ear on a bellhousing, trans case, etc. is trying to bolt things together with a piece of debris trapped between mating parts. All it takes is a few thousandths' gap that can't close up for a brittle casting to break.
