Winter is Coming
A good Tech Tip WINTERIZING YOUR TRUCK including a link back to the Forums for additional tips.
I have a 1946 1/2 ton pu running board that it looks like some one has jumped on it and slightly bent running board in a down ward direction at the front bracket and the bracket didn't move. I'm not sure how to go about straitening it out with out making it worse. Can some one give me some advise on how to fix this with out making it worse. Looks like the damaged area is about 3/16 with no creases.
I built a press of sorts to straighten the ribs on my running boards. I assume your '46 has the same ribs on it as the AD trucks. Here's a couple of pictures of what I built. I got a bracket for a bench of some sort at the ReStore and went from there, using some remnants from the USS Missouri rear bumper from my truck, but you could build one from raw steel.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
