| | | Forums66 Topics128,148 Posts1,056,810 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2017 Posts: 308 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 308 | We have Wagner 53 and 1895 lights in gauge cluster. Can we change to LED BA95 if they fit, without any modification? Thanks Bill | | | | | Joined: Mar 2014 Posts: 4,504 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,504 | If you mean BA9S, yes you can, but the LED lights won't dim with your light switch as the other bulbs do. These are (to my knowledge) all made in China and trying to figure out what the temp of them is before you buy them would be a good idea. 3000 would be an ok dash light temp. 5000 will be crazy bright white, 4000 will be very white and 2700 will make your numerals look more yellow-orangish in color as 2700 is really getting very deep into the warm scale. Good luck.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
