| | | Forums66 Topics128,142 Posts1,056,491 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Hi guys , are the 216 and 235 dipper conrods the same length?
I have a '48 235 that needs one crank journal ground and I have a set of 216 rods that have been resized for shells .
Hoping I can use the 216 rod in the 235 .
Both dipper engines .
Thanks . | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | In 1948 Chevrolet made the rods narrower than the earlier rods, but 216 and 235 Babbitt rods are the same
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2004 Posts: 29,821 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,821 | Rod length, journal, and wrist pin diameter are the same, and I've used a belt sander to narrow the early rods to run in the later engines. Just be sure he dippers stay centered by removing the same amount from both sides of the big ends. Longer stroke crankshafts are accommodated in several ways to keep the pistons from sticking out of the top of the block- - - -make the rods shorter, move the wrist pins closer to the top of the piston, or make the block taller. Chevy did it the hard way, by casting a different block when they built the longer-stroke 235. Another example would be the Ford 351 Windsor with a block an inch taller than the 302.
| | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Thanks guys , I appreciate your support . | | |
