1 members (lumbersawyer),
84
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 394 'Bolter | | 'Bolter Joined: Nov 2002 Posts: 394 | Is it possible to torque all, or like we call it Flight line torque the Bell housing bolts without removing the clutch/ flywheel assembly? | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 |
| | | | | Joined: Nov 2002 Posts: 394 'Bolter | | 'Bolter Joined: Nov 2002 Posts: 394 | | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Nope, I presume the bellhousing to block bolts.
Ed
| | | | | Joined: Nov 2002 Posts: 394 'Bolter | | 'Bolter Joined: Nov 2002 Posts: 394 | Looks like there are 2 bolts way up inside the bell housing I can not get too. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | With the flywheel removed, all can be removed or tightened with a .5" drive socket set with U- joints.
Ed
| | | | | Joined: May 2015 Posts: 11,040 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,040 | It's not possible to get accurate torques when using a u-joint. If there's any angle at all on the u-joint, the torque reading will not reflect the actual torque.
A better approach would be to use a crowsfoot installed at a right angle to the torque wrench if it's not possible to get the torque wrench on the bolt with a socket on it. With a little mathematics you could use an extender in line with the wrench stem.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | Why bother torquing? Like my first shop foreman used to say about cylinder head bolts- - - - -"Give 'em a good grunt!" (No, I didn't do it that way), but he would always give me the stink eye when I got out the torque wrench!
| | | | | Joined: May 2015 Posts: 11,040 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,040 | Torque 'em down till they break and back off 1/2 turn.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | Boy am I feeling lucky. I've never torqued a bell housing onto an engine in 55 years of backyard/barn monkey wrenching and have had no problems. I have replaced bell housings for others that had ears broken off and/or cracked. Too much torque or not enough?
Rick
1939 Chevrolet Stake Truck
| | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | Boy am I feeling lucky. I've never torqued a bell housing onto an engine in 55 years of backyard/barn monkey wrenching and have had no problems. I have replaced bell housings for others that had ears broken off and/or cracked. Too much torque or not enough?
Rick Yes.........we are NOT working on the bell housing on the space shuttle. Cracked causes .........misaligned, missing dowel pins or tightened when not seated against the block?
| | | | | Joined: Mar 2016 Posts: 225 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 225 | Proper/Correct Torque = 1/4 turn before you wring it off
Mike
1951 3100 5 window
| | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | The most common cause of a broken ear on a bellhousing, trans case, etc. is trying to bolt things together with a piece of debris trapped between mating parts. All it takes is a few thousandths' gap that can't close up for a brittle casting to break. Jerry
