9 members (Wayne67vert, TooMany2count, Nick in Manitou, NJC, Mike in Sycamore, Bill Hanlon, Ponchogl, sron48, rfs56trk),
85
Mod | | | Forums66 Topics128,137 Posts1,056,747 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2017 Posts: 62 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 62 | I plan to take out two head bolts on a 261 and use 2 slightly longer grade 8 bolts to attach my engine leveler to the head. Problem is I only have my 216 bolts as a guide for buying the longer bolts. Are the 235/261 head bolts the same size as 216?
1951 GMC 9430 long box w/ hoist 1952 GMC 9430 long box w/ hoist (sold)
| | | | | Joined: Feb 2004 Posts: 29,841 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,841 | The thread is the same- - -1/2"-13. 235 head bolts are different length than 216's, some are shorter are others are longer. Buy a couple of 1/2-13 X 6" Grade 5 or 8 bolts and use flat washers to take up any excess length.
Edit: DO NOT get tempted to use all-thread rod- - - - -it's Grade 2 or softer, and it could possibly break. 235's don't bounce very well!
| | | | | Joined: Jan 2017 Posts: 62 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 62 | Good advice, thank you Jerry. I don't plan on doing any bouncing!
