5 members (5 Window 9434, JW51, Ponchogl, Mike Roache, Charles in CA), 66 guests, and 1 robot.
Topics128,131
Posts1,056,722
Members48,454
I plan to take out two head bolts on a 261 and use 2 slightly longer grade 8 bolts to attach my engine leveler to the head. Problem is I only have my 216 bolts as a guide for buying the longer bolts. Are the 235/261 head bolts the same size as 216?
1951 GMC 9430 long box w/ hoist
1952 GMC 9430 long box w/ hoist (sold)
The thread is the same- - -1/2"-13. 235 head bolts are different length than 216's, some are shorter are others are longer. Buy a couple of 1/2-13 X 6" Grade 5 or 8 bolts and use flat washers to take up any excess length.
Edit: DO NOT get tempted to use all-thread rod- - - - -it's Grade 2 or softer, and it could possibly break. 235's don't bounce very well!
Good advice, thank you Jerry. I don't plan on doing any bouncing!
