2 members (BC59, Barry Martak),
64
Mod | | | Forums66 Topics128,179 Posts1,057,157 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2018 Posts: 51 'Bolter | | 'Bolter Joined: Oct 2018 Posts: 51 | Has anyone used the Filling Stations speedometer rebuilding service?
Alan | | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | I don't know about their speedo service, but The Filling Station has an excellent reputation locally. They do door hinge rebuilding too: https://www.youtube.com/watch?v=KY5emKPwGiY
1951 Chevy Panel Truck
| | | | | Joined: Jul 2000 Posts: 173 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 173 | Around six years ago, I had Justin's speedo (1928) lubed, re-magnetized, and calibrated by Commercial Speedometer in Sacramento (1-916-371-5873). I forget the cost, but it was around $150.
Still working well.
Cheers, Dean
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Alan,
Is your speedometer not functioning?
When I started driving my 1941 truck on the road, one day the speedometer began making a very bad screeching sound. Once inspected, the fix was quite easy requiring only one drop of oil. The truck has seen thousands of road miles since with no issues. Check out his tech tip as it certainly helped me out.
https://www.stovebolt.com/techtips/gauges/speedometer/COE090.jpg
Paul
As the speedometer bushing has most likely not been oiled since the truck was produced in 1946, I would recommend oiling it as demonstrated in the tech tip. Getting the little brass plug out is a bit tedious, but with patience it can be done. It worked wonders on my truck.
Paul | | | | | Joined: Feb 2008 Posts: 1,124 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,124 | I refurbished the speedometer on my ‘46 project using the Tech Tip provided in the Stovebolt. It was a worthwhile learning experience and the effort worked, for a short while. I ended up having to send it in for a more work. I used a guy in Grand Island, NE. He went through the whole thing again and recalibrated it. It turned out there was more dismantling needed to clean and lubricate parts than the Tech Tip shows for this model speedometer. He told me to get into the parts not cleaned previously that some “special” tool(s) were required. The AD model speedos are apparently slightly different than the ‘46 version. | | | | | Joined: Feb 2008 Posts: 1,124 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,124 | Alan I too decided I’d try refurbishing the dash cluster myself for mostly the same reason. Even if I botched the effort, I’d still win, because I’d have learned something along the way. May not be the same warped way to look at this hobby by a lot of others, but I like the challenges, usually. The speedo was the only problem I had in rehabbing the dash cluster.. If I knew more specifically what the extra steps and tools were the rebuilder referenced that completed Sparky’s speedometer rehab, I think I could have done it right before. However, he wasn’t all that forthcoming with the details. Which, I might add, leads me to suspect it might not be as difficult as indicated?
