0 members (), 150 guests, and 7 robots.
Topics128,077
Posts1,056,033
Members48,433
#1286098 11/04/2018 8:40 PM
Is there a vacuum port to tune the air/fuel mixture or am I to gauge it with RPMs? Also, am I aiming for 500 rpms as factory spec?
1963 C10 Fleetside Long Bed; 230; 3 speed; gun rack.
Riding in the Passing Lane
The vacuum port is on the side of the intake manifold. It has a fitting in it for vacuum wipers or a pipe plug. You can adjust the idle mixture without it. With the engine running at idle speed & warmed up, slowly turn the idle mixture jet in till the engine starts slowing down. Then back it out to the highest RPM, usually 1/2 turn. 5-6 hundred rpm is about right for that engine unless it has an auto matic trans. or a/c. Georgeeeeeeeeeeee.
1972 Chevy c10 Cheyenne Super
Is the port inside? Under the air cleaner? This is the type B carb.
The port is below the carb on the flat surface of the intake manifold where the runners all come together. The outlet on the carb where the line to the dist. connects is ported vacuum. It is not useful foe testing.
Georgeeeeeeeeeeeeee
