3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#1285824 11/02/2018 3:17 PM
Looking for a source for a reasonably priced diaphragm for a mechanical fuel pump on a 49 3100, 216. Have found some in the $20+ range but that seems steep to me.
Ed
Y
yar Offline
Y Offline
Ed,
I found a Ford fuel pump diaphragm that was a perfect fit in my '36 Chevy for $7.50 at Sacramento Vintage Ford parts. So comparing yours to a Ford item may be an option. Is there a Ford parts vendor in your area? It seems that there is a lot of car activity in Las Vegas.
Ray
yar #1285908 11/03/2018 10:36 AM
Originally Posted by yar
Ed,
Ray,
Is the diaphragm you mentioned compatible with modern ethanol fuels? Would you happen to have the Ford part number?
Lots more pictures
Y
yar Offline
Y Offline
Good morning Paul. I asked about the ethanol fuel compatibility and the vendor didn't know. Here's what's written on the container: Sacramento Vintage Ford 05869 Diaphragm Fuel Pump 1935-40 Bin 20-047. Below the bar code is number 05869. Ethanol has been in gas for a long time. But this part is probably from China and we all know that China specializes in making really low quality stuff. This part has worked OK in my '36 Chevy PU for at least 5 years now. Because I said that it will probably fail next time I start the engine. Good luck!
Ray
Thanks for the numbers Ray. I will look into this. It is always good to find alternate work-arounds when sourcing parts. Funny how parts between competing auto companies can sometimes be compatible with these old vehicles, way different than in the modern era. I found that Ford vacuum wiper gaskets fit Chevy wipers perfectly.
Lots more pictures
Thanks for the tip on Sacramento Vintage Ford. Looks like I can get two for around $25 shipping included.
Ed
