0 members (), 137 guests, and 0 robots.
Topics128,102
Posts1,056,184
Members48,436
I have a 53 GMC 9300 and I think something is missing on the underside of the hood.
I have looked at several other posts and I see people talking about springs and cross supports on the under side of the hood. All I have under mine is a hinge on either side with no spring.
The hood has a suppot rod to hold it up but it seems a little flimsy to me when its up.
Their should be springs there. Sometimes people cannot get the hood to sit down properly with springs so they take them off. Other times the springs get stiff and fold the hood in half when you pull down on it so they are removed again.
Here is a picture of the spring you need. If you need a picture of the cross support let me know. I will take a picture and send it to you. http://rides.webshots.com/photo/2944537390032470346syENVI
Hope this helps. Cecil......
Thanks guys I thought there were a couple of things missing.
Cecil;
Thanks for the picture it help explain what the bolt holes were for on the firewall and hood.
If you could send me a picture of the cross support I would appreciate it. I have no idea how it would go under there but I figured something should stop the hood from being so flimsy.
Dave
