0 members (),
126
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 66 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 66 | I have a 53 GMC 9300 and I think something is missing on the underside of the hood.
I have looked at several other posts and I see people talking about springs and cross supports on the under side of the hood. All I have under mine is a hinge on either side with no spring.
The hood has a suppot rod to hold it up but it seems a little flimsy to me when its up. | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Their should be springs there. Sometimes people cannot get the hood to sit down properly with springs so they take them off. Other times the springs get stiff and fold the hood in half when you pull down on it so they are removed again. | | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | Here is a picture of the spring you need. If you need a picture of the cross support let me know. I will take a picture and send it to you. http://rides.webshots.com/photo/2944537390032470346syENVI Hope this helps. Cecil...... | | | | | Joined: Jul 2007 Posts: 66 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 66 | Thanks guys I thought there were a couple of things missing.
Cecil; Thanks for the picture it help explain what the bolt holes were for on the firewall and hood. If you could send me a picture of the cross support I would appreciate it. I have no idea how it would go under there but I figured something should stop the hood from being so flimsy.
Dave | | |
