3 members (asilverblazer, wvstovebolt, Bill Hanlon), 135 guests, and 3 robots.
Topics128,083
Posts1,055,967
Members48,430
Is there just a switch replacement or equivalent for the dome light?
Rest of the unit is fine it's just the switch gave way after 64 years.
1954 3600
Does it happen to have a plastic lens? I have one with a plastic lens. The rest of it looks just like my '52 and earlier fixtures. PM me if you need it.
Anything can be fixed depending on ones fabrication skills. This particular task may not be worth the trouble.
Carl
Thanks! It does have the plastic lens and the unit is complete. Just where the switch attaches broke in two and fell apart. Did search for little switches that might fit but gave up and bought a complete unit for 27 bucks on Ebay.
Will transfer the guts from that one into my unit.
1954 3600
You might still be able to find a switch at a flaps or hardware store, fix the spare and then get your $27 back from ebay.
Another quality post.
Real Trucks Rattle
' Offline
RocknTommy ,
Back in 2013 , I bought this one on ebay .
It was GM NOS with the original Guide box.
I have not seen one on ebay nos since .
It's a rare part and very hard to find.
PIC
https://i.postimg.cc/jqcFfjQj/GM-5937080-NOS-Dome-Light-Body.jpg
Finally this Bezel & Lens showed up on ebay last year
to complete my nos restoration of the interior dome lamp .
PIC
https://i.postimg.cc/nrrYBnps/1954-Dome-Light-Lens-and-Bezel-Guide-NOS-2.jpg
I picked up a spare nos lens last year.
PIC
https://i.postimg.cc/Kc35GvqV/Guide-Dome-Lamp-Lens-5942293-NOS.jpg
Additional lamp body assembly pic
PIC
https://i.postimg.cc/1tqNQ4mr/GM-Guide-Dome-Lamp-Body-5937080-NOS.jpg
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
Insomniac
Insomniac
The switch on my dome light failed so I bought a simple slide switch at the Source/Radio Shack. Used a couple of small pop rivets to hold the new switch in. Soldered up the connections and it works just fine. Cost/benefit analysis of my labour vs buying a replacement probably favours buying a replacement, but it was more fun to fix up the old one.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Nice!
1954 3600
