| | | Forums66 Topics128,049 Posts1,055,678 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2018 Posts: 163 Jolly Roger | | Jolly Roger Joined: Jul 2018 Posts: 163 | Now that I’ve gotten the engine running to factory standards, the question of overrev comes into play. I know it doesn’t have a governor but it also isn’t VVT so overrev wouldn’t hurt more than the bearings over a long period. I know the highway going 45 cruising RPM is something like 3500-3800. What I want to know is what will the engine run at with full throttle in neutral and what would be considered red lining it. Also how much damage would be done to it if it is ran at full throttle for a few seconds.
Owner of the most temperamental 1951 3100 in existence
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Running full throttle at no load is a surefire way to do major damage to the rod bearings of any engine. If you're running a 216 with cast iron pistons, that's a very good way to hammer the Babbit bearings into nothing in a very short time. The engine will run pretty much forever at 3500 or a little more as long as it's done while pulling the vehicle. Revving it up in neutral is an exercise in stupidity. Jerry
| | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Mr Dane has a '54 235 in his 1/2 ton . Great engine . but 3800rpm at 45mph ??? need a new rev counter . RPM Calculator; http://www.csgnetwork.com/multirpmcalc.html | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Maybe in 2nd gear with the heavy duty 3-speed (3.90 rear) = ~3800 rpm | | | | | Joined: Jul 2018 Posts: 163 Jolly Roger | | Jolly Roger Joined: Jul 2018 Posts: 163 | i dont think its hitting 3800 thats just what i saw in another form post. i need a rev counter as it stands lol
| | | | | Joined: Jul 2018 Posts: 163 Jolly Roger | | Jolly Roger Joined: Jul 2018 Posts: 163 | its just got a stock 4.11:1 that came on the 1/2 tons.. so from what ive read on other sites it could be somewhere from 3200-3800. either way thats a pretty good running speed..
| | | | | Joined: Jul 2018 Posts: 163 Jolly Roger | | Jolly Roger Joined: Jul 2018 Posts: 163 | hopefully that'll never happen. ill just make sure im the only one that drives it.
| | | | | Joined: Jul 2018 Posts: 163 Jolly Roger | | Jolly Roger Joined: Jul 2018 Posts: 163 | anyway ive found what im looking for thank you all for the help!
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Standard 1/2 ton? Stock trans ans rear end? And a 235? That is the same setup I have in my 52. With a decent tach on the column I read 3000 RPM at 60 MPH. 235 15 tires and wheels. So, try to get a good reading on the engine RPM. My truck sounds "busy" at 2500/2700 RPM(that is close to 55 MPH) so I do tend to stay right around that speed. It will go as fast as 65, but neither me or the truck feel real happy for long at that speed. I do some "freeway" driving. Not avoidable in Utah, but I don't go far from the right hand lane. Hot Rod thinks 3500 is fine. Trust him. Here is one, kinda spendy but a good counter: https://www.autometer.com/2-5-8-tach-4-000-rpm-low-rev-black.html
Steve H
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | 235's from 54-62 were factory max HP rated at speeds from 3800-4200, depending on the year of the engine. With good rod bearings and good oil pressure, these engines will stay together and produce more HP than most of us will ever need at speeds we're afraid to approach. If an engine is noisy at lower speeds, it's either worn out, or we're just not accustomed to hearing one earning its keep at its HP-rated RPM. The bigger trucks with plenty of gears got run at or near redline pulling max loads or above all day and stayed together. Jerry
