1 members (CuzzFuzz),
228
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 53 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 53 | I have a 49 GMC FC 101 with a SBC. I want to add A/C/heater/defrost. I used Vintage Air in my 69 Camaro a few years ago with good success so I am leaning that way but I thought some of members of this site may have some other suggestions to look into. As I see it the Vintage system for the Series 1 Chevy/GMC truck will cost me about $1,500.00.
Any suggestions would be appreciated.
Tom | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | For premium units we prefer the Old Air unit over Vintage as it works just as good and retains a full size glove box. For an economy unit we use an under dash unit from Lucky"s in Ennis, Texas. He usually has them at shows for around eight to nine hundred dollars for a turn key set up and they are not the ugly box looking unit. This pic of one in a 49 doesn't show the entire unit but gives one the idea of the looks. [img]https://i.postimg.cc/Hc5MkLxr/dan-s-49-010.jpg[/img]
Evan
| | | | | Joined: Feb 2000 Posts: 5,215 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,215 | I just put a Vintage air Mini Compact unit in my '37. It blows 38 degree air even on the hottest days. It will freeze up if it's humid out, but I heard before purchasing it they could do that. I am really happy with it, but it was expensive, not quite $1300 with everything needed to finish the job.
Best advise I can give is get the cooling system working correctly before adding air, fan shroud and good radiator. If you can't move the heat out of the condenser and radiator, it doesn't matter what A/C system you buy, it won't cool! I have a 18" mechanical fan with no clutch on a 250 inline with a 17" wide radiator just to be sure it stays cool. | | |
