3 members (dt235sd, Tom McGrath, 55shaker), 94 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
I'm replacing the rocker panel (side sill per the FAM) on the driver's side and need a location for it fore and aft. There's really nothing left to reference to except for the face of the firewall that's used in the FAM for a horizontal dimension baseline. Unfortunately the large hole in the front of the rocker isn't listed in the dimension page.
If someone has a cab that still has the rocker in place and not rusted off, I'd sure appreciate a dimension from the plane of the firewall back to the larger of the 3 holes.
See the attached snip from the FAM for what I need.
Thanks a bunch
Bump
Anyone?
You didn’t tell us what you’re working on. Maybe that info would help. Surely someone can provide the needed info then.
You are correct, but it's the 51 3100 in my signature. I doubt that anyone would assume I'm asking here on the 'Bolt about the Model A's I had. Just sayin' wink
No, but you might have acquired a “new bolt” without telling us. Now let’s hope help is on the way. shake
Another bolt??? I'm not that crazy (yet). This one is quite enough.
So I'm closing the loop on this. I FOUND THE LOCATION FOR THE ROCKERS. yahoo
After locating the passenger side rocker with the notches for the weatherstrip retainer in the floor, I moved on to the driver's side rocker, which had no holes left to reference to. The toe board was also gone where the parking brake pedal bracket goes so using that as a reference was a little iffy. After screwing the rocker in place for fitting other parts, I stopped and scratched my head about whether I got it right. I checked against the passenger side rocker measuring from the A-pillar to the large hole for the parking brake shaft (for some reason there is a hole there too.) and found that it differed by about 1/2 inch. Then I went back to the cab dimensions in the FAM and found a dimension at the bend in the floorboard/toeboard. Looking closely at the figure (Sect 1 Sheet 1.07), there was the end of the rocker. dang Going back and checking, I was within 1/16 inch of that front of dash reference. smile After all that messing around, it would have been simple if I had found that dimension a long time ago. Seems that the holes in the front of the rockers aren't in the same location reference from the front end (my rockers were from two different sources.)
So for you guys who might be at the point of installing new rockers (I know there's a few of you), The end of the rocker should be 8.47 inches to the rear of the face of the firewall. I just clamped a piece of channel to the firewall to measure from.
Has anyone replaced a complete floor pan I would like to see pictures of how it looks in the door opening. And I hate to seem totally ignorant, but what is the FAM. And how to access?
Factory Assembly Manual.
