0 members (),
83
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 168 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 168 | Question: are the 1/2 ton through 1 ton advance design bellhousing crossmembers (or rear engine mount crossmembers, however you want to term them), the same dimensions?
So, I have limited experience with the lighter duty trucks. I've just had 3800 and 6400 trucks, and I was wondering if the lighter trucks' crossmembers were the same as the 3800.
Reason being, I've got a 3800 frame that I would like to put a '54 or '55.1 crossmember in that has the angled mounts, so I can use the later inline 6/v8 bellhousing.
I just need to know if I need to get one from a 3800 frame or if a 1/2 or 3/4 ton crossmember will work.
Liquidated my projects Now looking for a decent '47-'55.1 3100, 3600, or 3800
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Look in the parts manual, Section 7.229 Picture http://chevy.oldcarmanualproject.com/parts/1929_54/413.htmParts listing http://chevy.oldcarmanualproject.com/parts/1929_54/421.htmThe 47-53 list one part number for commercial and utility... I'm not sure but that may be 1/2 ton through 2 ton?? 54 has part number for 1/2 and 3/4 ton, and another for 1 ton, and two more part numbers for larger yet. What does that all mean? Which 54 model crossmember is interchangeable with which earlier models? What's the real difference between the various 54 model crossmembers, are they different shapes/sizes, or only different material thickness(might be functionally interchangeable?), or??? | | | | | Joined: Jun 2005 Posts: 168 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 168 | Sheesh, I imagined it would be simpler. I might just have to weld one out of plate
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Before doing that find some 54 crossmembers to try and let us know what works. | | | | | Joined: Jun 2005 Posts: 168 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 168 | I'll see what I can drum up
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | The rear engine mount crossmember is made up of a few pieces. When test fitting consider you may be able to use the smaller pieces from your original with the main member form the 54. I can't say for sure this is useful, but worth checking. | | | | | Joined: Jun 2005 Posts: 168 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 168 | Okay, I need to see a picture of a 54 or 55.1 crossmember.
I finally got to looking at the link you posted, and it has some great information that's clearing up some questions.
I knew most of the advance design rear crossmembers were 3 piece (1 long that was riveted to the top flange on the frame and two smaller supports that were riveted to the bottom flange of the frame and to the long piece).
The long piece has the same part number for 47-53, and it's the two smaller supports that are different depending on the truck you get (height of frame rail).
The 1/2 and 3/4 ton trucks share the same smaller supports.
The 1 ton and 4100's share the same supports. This makes since because the frame is identical from what I can tell; however, I did stumble on the heavy duty option for the 4100 which basically turned it into a 6100.
All the 4400's, and 2 tons share the same supports.
So you basically had three sizes depending on the frame rail height of your truck.
'54 has the same breakdown: one for 3100 and 3600, one for 3800 and 4100 (except heavy duty 4100), and one for the rest of the heavy trucks.
So, I'm guessing that the 54-55.1 series crossmembers are either one piece, or the parts people at GM started selling the whole unit with the supports and quit assigning individual part numbers.
This brings me back to my first sentence.
A picture of a stock 54 or 55.1 crossmember would solve this for me if anyone has one handy.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | http://www.1954advance-design.com/Documents/EngineeringFeatures/slides/orig_Page49.html
http://www.1954advance-design.com/Documents/EngineeringFeatures/slides/orig_Page50.html | | | | | Joined: Jun 2005 Posts: 168 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 168 | Excellent sir, many thanks
