5 members (baldeagle, cmayna, GMCJammer51, dt235sd, 1 invisible), 70 guests, and 5 robots.
Topics128,017
Posts1,055,338
Members48,419
#12849 03/26/2002 10:35 PM
I have 2 different style heaters.Both supposedly out of 54's. One is the box style w/doors that open and shut and in this truck I just bought it has what I call a seashell looking heater motor. can anyone explain the differences and which one is the better one?
Alan
Live every day to the fullest for tommorrow never comes!!!
#12850 03/26/2002 10:58 PM
Alan, there are two types of Chevy factory accessory heaters for the '54 truck; one is a "Fresh Air Heater" which attaches to the kick panel and circulates fresh air through through the intake louvers on the side of the passenger cowl and then blows that air over the heater core and into the cab, the other is a recirculating heater which is attached to the firewall and simply takes cab air and "recirulates" it over a heater core.
There is a peculiarity to the '53/'54 truck fresh air heaters in that they added a recirculation feature which incorporated a double door flap that would close off the cowl intake and open up a cab air intake to recirculate cab air too.
I'm a GMC man and will further confuse this issue by stating that GMC offered three heaters for '54 GMC trucks: a Special Heater (recirculating only), an Airflow Heater and Defroster (fresh air heater), and, an Economy Heater which was recirculating and the least expensive way to get some heat on cold feet.
The link below illustrates the GMC heater options for 1954:
1954 GMC Heaters
#12851 03/27/2002 1:49 AM
I think the box shape with doors you are describing is not a GM heater but an aftermarket. Otherwise it's as Oldcarcook described.
54 3100 with 235
62 flatbed dump C60 with 261
#12852 03/27/2002 5:20 AM
Thanks Old,
The one I have in my driver truck is the air over the heater core and doors type, The one I just got must be the encono one cause it looks like it would only be a foot warmer!!
Thanks again,
Alan
