| | | Forums66 Topics128,037 Posts1,055,470 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2017 Posts: 120 'Bolter | | 'Bolter Joined: Jun 2017 Posts: 120 | Can anyone tell me if the firewall pad and cover was glued in place or was it only held in with the push in clip hook things?
Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The firewall pad/cover was held in place with the clips. There were probably also pieces of some sort of sound deadener attached/adhered to parts of the firewall.
If I remember, I will check the Factory Assembly Manual tomorrow. | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | Correct Tim, there were the thin glued on insulation pads, and then the big pad was held on with the clips over them. | | |
