4 members (greenie-reddy, Jon G, cmayna, dt235sd), 26 guests, and 4 robots.
Topics128,021
Posts1,055,372
Members48,420
#1284110 10/19/2018 1:09 PM
I need new Truck Angle Bed Strips for my shortbox stepside. I believe the bed is from an early 60's chevy but don't know the exact year. Is there a way I can figure this out because I want to make sure I order the correct angle bed strips. I know the box didn't come from a 55.2 or 56, which my truck is a 56 and I had to have a guy make it fit on my 56. If there isn't a difference, then great, but again just want to make sure. Thanks for the help!
1956 Chevy 3100 Stepside Shortbox
More pix on Photobucket
Give Mar-K a call 844-627-5844. They are experts on truck beds and very helpful.
Harold
Harold
OK thanks!
When you call make sure you have the critical measurements of your bed. They are going to ask. They may request photos. Good folks and if they can they will help you. 🛠
Sir Searchalot
Sir Searchalot
The angle strips are sold by length or buy some angle and paint. How are you going to attach angle strips to the bed sides? The angles are sold punched or not punched. Seems like you want punched. Then drill holes for side mounting and drill wood to match punched square holes. I think the only difference in 55-59 and 60-66 are the holes but that may not matter depending on what you have that is already drilled or not.
OK thanks guys, this helps a bunch.
