3 members (DES57, TUTS 59, 1 invisible),
83
Mod | | | Forums66 Topics128,035 Posts1,055,447 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 349 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 349 | I need new Truck Angle Bed Strips for my shortbox stepside. I believe the bed is from an early 60's chevy but don't know the exact year. Is there a way I can figure this out because I want to make sure I order the correct angle bed strips. I know the box didn't come from a 55.2 or 56, which my truck is a 56 and I had to have a guy make it fit on my 56. If there isn't a difference, then great, but again just want to make sure. Thanks for the help! | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Give Mar-K a call 844-627-5844. They are experts on truck beds and very helpful. Harold
Harold Is a restoration ever finished? | | | | | Joined: Apr 2009 Posts: 349 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 349 | | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | When you call make sure you have the critical measurements of your bed. They are going to ask. They may request photos. Good folks and if they can they will help you. ðŸ›
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The angle strips are sold by length or buy some angle and paint. How are you going to attach angle strips to the bed sides? The angles are sold punched or not punched. Seems like you want punched. Then drill holes for side mounting and drill wood to match punched square holes. I think the only difference in 55-59 and 60-66 are the holes but that may not matter depending on what you have that is already drilled or not.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2009 Posts: 349 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 349 | OK thanks guys, this helps a bunch. | | |
